SHEAR MODULUS AISI 316
Which is the shear modulus for a spring made from AISI 316 ?
RE: SHEAR MODULUS AISI 316
http://www.alleghenytechnologies.com/ludlum/pages/produ...
Cory
http://www.aksteel.com/pdf/markets_products/stainless/a...
Now, all spring references that I checked (SMI Handbook, SAE HS 795, Rockwell Mechanical Spring Design Guide, etc.) use the value of 69 GPa or 11 x 106 psi for the value of G for austenitic stainless steels like Type 316. This is confirmed by some European spring wire producers of Type 316 (EN 1.4401) like Ugine and Sandvik:
http://www.uginesavoie.fr/system/online/sources/Documen...
http://www.smt.sandvik.com/sandvik/0140/internet/se0159...
Also note that the strength and moduli increase after tempering, so the value of 71 GPa is probably the most appropriate design value for a spring using Type 316 wire.
