Old Data for GE Lrage AC Motors
I am searching for old GE data and a drawing for an 8309S frame, ODP, 1000 HP motor. Does anyone have a source that will help me find a drawing and data for the following? If so, I would appreciate your help.
MOTOR INFO:
GE
1000 HP
1185 RPM
8309S Frame
2300 Volts
232 Amps
ODP
1.15 SF
Model # 5K83095301/ 5K83095301
Serial # 8325396 / 8357588
DATA NEEDED:
Speed / Torque Curve
LR Torque and Amps
BD Torque
Rotor WK2
Efficiency
Max WK2 of Load
MOTOR INFO:
GE
1000 HP
1185 RPM
8309S Frame
2300 Volts
232 Amps
ODP
1.15 SF
DATA NEEDED:
LR Torque and Amps
BD Torque
Rotor WK2
Efficiency
Max WK2 of Load
RE: Old Data for GE Lrage AC Motors
Try and enter an inquiry on the following input form
http://www.geindustrial.com/industrialsystems/contactus/techquestion/techquest.jsp?referrer=/industrialsystems/support/technical/index.jsp
I've taken the liberty to enter the information you supplied. However, I wasn't able to enter your name or phone number... you may want to enter the information into a form yourself and supply contact information by which they can contact you ..
Let's see what we can get...
I've hammered on GE repeatedly that it is impossible from a user apsect to get technical support on older products because they do not identify their technical resources to the public.
If it comes up blank... I have a couple of other paths to
pursue ..
jO
Source at GE Industrial Systems advises that the GE Technical Center should be able to provide you with the motor data you are chasing.
1-877-521-5252
Would appreciated some feedback on how this works out for you.
Thanks.
jO
Yes these motors were built else where, likely Brazil. I spoke to GE's Technical Center as suggested by JOmega. They will supply data for $250.00.
We have contact our client...
In the interum I created my own data sheet with a drawing based upon measurements.
Thanks Again!
TEECO1
http://gess.ge.com/pdf/acdc_mo_4_large_ac.pdf
for GE AC large motors:
Large AC refers to motors whose outer stator diameter is 54 inches or greater. This motor line was produced primarily by GE in Schenectady, NY and Peterborough, Ontario. (Incidentally, Ontario is in Canada.)
