Sheet metal cylinder with flange
I am trying to figure out a way to draw a Sheet metal cylinder (dia 6") with a .313 flange at the bottom of it. Any ideas????
RE: Sheet metal cylinder with flange
A picture would help.  If you wish, send a small (<300 Kb) picture to the email address in my profile.
I think he's talking about an "L" shape revolved into a cylinder.  I don't think SW will be able to unfold a part like this.  It will only unfold linear bends, not curved.
MadMango
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
You got it Mad, it is (or should I say would be)an L revolved.  In the previous years we have been faking the flat by adding the flange material I was hoping something would have been changed by now.  Thanks for the time guys.
I am kinda a novice when it comes to what can actually be manufactured out of sheet metal.  I don't quite see how that part can be manufactured.  It seems like an aweful lot of "stretching" at the short leg of the "L".  Please inform me as to how this part gets mad in the real world.
DB
I suspect it would be roll-formed.  Many bearings (Garlock DU Bearings) are made in this shape, it's very common.
MadMango
Yes, roll-formed or deep pressed. If these are the cases, there's no point of using sheet metal. Am I right?
Yeah, its roll formed then welded along the seam.
So I think the best way is to use a revolve feature, as SW does not understand nothing about plastic deformation processes (other than the "normal" sheet metal). If it's important to you the deformation analysis, you should search for apropriate software.
