EXPLODE LINES IN SHADED VIEWS
I am currently evaluating SWX2004 and am having problems with explode line sketches. In the assembly file I create an exploded view and then apply explode lines. When the exploded view is then inserted into a drawing file the explode lines dissappear when the view type is shaded. They can be made to re-appear if the view type is switched to hidden line removed. Is this a bug or a limitation? It certainly worked in SWX2003.
RE: EXPLODE LINES IN SHADED VIEWS
Yup.  Works in 2004SP01.  Ya-hoo!
