how do I limit sensitivity on moving or rotating parts in an assembly
The problem is I'm trying to demonstrate how one thing will react to another in a gear train, and I have tried to move or rotate the driving shaft, which operates a series of gears. everything is properly moving, but its very hard to show smooth motion. the slightest motion in my mouse shows erractic changes on the system. Is there a setting i can change to alleviate this problem?
RE: how do I limit sensitivity on moving or rotating parts in an assembly
MadMango
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Or you could even (temporarily) add a handle to the shaft to grab and move
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
You might see if your VAR will sell you the tutorials that are used in the sessions of training. They used to sell those but now they may not, so you will take the training instead.
Scott Baugh, CSWP
FAQ731-376
