collapsible mandrel for filament winding
i want some references regarding the collapsible mandrel for filament wound pressure vessel.
i am interested in such tooling which can be removed easily from the vessel after winding.
Any comment will be highly appreciated.
RE: collapsible mandrel for filament winding
Is this correct?
REFERENCE BOOK.
User's Guide to ASME Standards for Fiberglass Tanks and Vessels ASME SECTION X
by Peter J. Conlisk and John E. Niesse
MTI Publication No. 50
ISBN 1-57698-005-7
Materials Technology Institute of Chemical Process Industries, Inc
1215 Fern Ridge Parkway, Suite 116
St. Louis, MO 63141-4401
tel 314 576 7712
fax 314 576-6078
User’s Guide to ASME Standards for Fiberglass
Tanks and Vessels
An essential primer for everyone involved with FRP equipment , especially for process industry uses. The only instruction book specifically written to help engineers specify fiberglass (FRP) tanks and vessels to ASME RTP-1 - 1995 Edition, Reinforced Thermoset Plastic Corrosion Resistant Equipment, and Section X of the ASME Boiler and Pressure Vessel Code, Fiber-Reinforced Plastic Pressure Vessels. Gives detailed examples using actual UBRS (User’s Basic Requirement Specification) forms in RTP-1 and design specifications required in Section X.
RTP-1 includes six How-To-Do-It examples, with engineering drawings, for vertical, vented, flat-bottomed storage tank, vertical dished bottom surge tank, vertical dished bottom reactor, vertical, agitated vessel, box-shaped plating tank and absorber (scrubber).
Section X has three How-To-Do-It examples, with engineering drawings, for horizontal surge vessel, and packed column.
This book includes a history of RTP-1 and Section X plus fiber-reinforced plastic technology: Resins, fibers, corrosion resistance, filament wound and contact molded laminates, and hand-layup and joining fabrication.
1996 by MTI, 81/2" x 11", hardcover, 144 pages, 24 figures, 1 table, 6 chapters, preface, references, glossary of terms, and index.
http://www.mti-link.org/
User's Basic Requirement Specification, ASME RTP-1-1995 ASME.
WWW.ASME.ORG
I hope this will help your
Leonard Thill
www.thill.biz
Do you have any idea how to prepare metal (collapsible) /non metal mandrel for the ASTM D 2585 test bottle. I am looking for some book or refrence to construct mandrel for filament winded pressure vessel.
Thanks again.
