Sheet Metal Cone??
Sheet Metal Cone??
Is it possible to create a cone in Silidworks 2004 using the sheetmetal commands so it can be unfolded?? If so how do i do it? Thanks for any help
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Sheet Metal Cone??
The help section has good instructions on how to do this also.
Basically you are creating a thin feature loft. You create two open sketches. In your case, two circles with a small gap. The circles are concentric and on two seperate planes. The go to INSERT> SHEETMETAL> LOFTED BENDS>. You can then input your mat'l thickness and viola its done.
thanks for the help guys, i really appreciate it!!
