How do I use the net use command with a Novell
login script?
This is a Novell environment. I'm using Netware 5x and I setup a group "tessitura" on my server. I have a SQL server with a shared folder tessitura/startup. How can I use the net use command in the netware login script to map the "tessitura" group to a drive letter.
thanks
