Matlab function block in simulink
How can I include a matlab user defined function with two inputs and two outputs to a simulink "matlab function block" ?
RE: Matlab function block in simulink
I could get two inputs fed to the function block by using the "mux" block. Now I am facing another issue.
In the function, the returned value is a real number. And I set the output width as 1 and set the output type as real. But  simulink gives an error "Evaluation of expression resulted in an invalid output.  Only finite double outputs are supported".
Does anyone have any idea about this?
Can you send a copy of the model for me to look at ?
Hi there. There is a block in Simulink called the S-Function block where you define the number of inputs and outputs. In order to use this block, you need first to develop a script using MATLAB Language and save it in an m-file. Then call the m-file into the S-Function block. Try to consider the "help" portion in the MATLAB Web Site.
http://www.mathworks.com
Emmanuel A. Gonzalez, E.C.E.
