Thermal dissipation of concrete
I am attempting to calculate the rate at which concrete, batched using heated aggregates will loose this heat to the surrounding air when cast as a slab on a cold formation. I am really interested in the period prior to the initial set, before the concrete has started to produce any heat of it's own.
Can anybody tell me how I should go aout calculating the rate of thermal dissipation? What equations should I use? Are there any papers that I could refer to?
RE: Thermal dissipation of concrete
Hi  nobler
You should try this site: http//www.hyperpave.com/
Download the demo.  It is a powerful program.  I don't know if it will answer everything you are looking for, but it is worth a look at.
