Performance Still need help
Hello All,
I am running R11 SP4. I was wondering if anyone knows of any other settings I can turn on or off to increase performance, And will my Hardware handle it. I have a Progressive die with about 700 parts that is 500megs. I am running HP XW4100, P4 2.80mhz, 2gig RAM, NIVIDIA 980XGL graphics. We are also running Smarteam. It seems to that saving files is a problem too. Any help would be great.
Kind Regards
RE: Performance Still need help
Your system should be able to handle a model of that size I'm working with models of up to 3000 parts with an IBM petium 4 1700 with a fire gl card and 1GB memory.
This is in 5R10SP3.
I've seen the same model load in 5R12 in about 1/5th the time.
So there is definitely some improvement there.
Puck,
Any good settings in v5 I can try?
Turn on Cashing.  Load your assembly. Close your assembly.  Now CATIA will be using CGR or CATIA Graphic Repesentations.  When you need to change a part you will need to activate the part before modification.
