Plotting with a script or IUA
I was tasked to find a way to plot sheets to a plotter using  a script file or IUA.
The process being used currently is a template sheet is created on layer 0 then subsequent layers (1,2,3,...) contain the text/graphics for different operations.  The operator then applies a filter that contains layer 0 only goes to each layer for each operation and using the interactive 'PLOT' function to plot each sheet (usually using the quick-plot option).
I have looked in the IUA manuals we have and I don't see a 'plotting' command.
Can I write a script to do this?
Can I write an IUA to do this?
Any help would be greatly appreciated.
mjs
