Exporting Step214 files from UG NX
I'm exporting step214 files of assemblies from NX.
When I read the step file in to NX again to check the step file I can see the parts included in the assembly have been renamed to "UNPARAMETERIZED_FEATURE".
I believe it is possibly to maintain the original part names in the step file which is a great help when discussing the assembly with external clients.
Can anyone help with this?
Chris
Chris
RE: Exporting Step214 files from UG NX
To maintain the assembly structure in STEP and IGES, export using the external translators.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I have also experimented with several configurations within UG. I had success with generating a step214 file of an assembly if I chose "Existing part" under "Source specification method" instead of "select from displayed part". (all parts to be exported need to be fully loaded)
Thankyou for your help.
Chris
Basically it comes down to this: if the export is being doen from the loaded part, you lose the assembly structure. If you do the export using the file as saved on disk, then the assembly structure is maintained.
Ben Loosli
Ingersoll-Rand
Has anybody successfully transferred meta data between systems. I'm using STEP214. Is there a third party software utility that can be used?
As far as I know, no such info goes with the STEP translation. I think Ben gave you the best answer here: Thread561-82464.
Yes Cowski your right, Ben did have the answer, I was backing off from my original plan of exporting "all" product data to just getting some attributes but it seems UG can't even export that. Can it really be that hard to export metadata? I guess it is. The UG Help just gave me a similar answer.
RW
