Exhaust flange sealing
I have built a one off exhaust system and the sections of pipe and manifold are joined with bolt together flanges.
I would like suggestions as to how to seal these flanges. My thoughts are for a silicon sealer, gasket sealer or a gasket material.
Pictures of my application can be viewed
http://www.beardmorebros.co.uk/website%20pages/new_proj...
Thank you
John
Thank you
John
RE: Exhaust flange sealing
pat
I have heard, from one of the local drag racer types, that on SBC's the thicker plate results in the header assm not loosening as often as thinner plates---seems logical.
Point of fact---I generally use a slip fit on any exhaust systems on the vintage road race cars. They sit to low for clearance of a big flange and rules ban floorpan mods.
Rod
try Welltite. It is a cousin to Hylomar and was discovered/invented to seal WW2 tank head gaskets. I have not used it personally but it gets rave reviews in the UK.
BTW...you dont have Mcmaster-Carr over your way.
As a suggestion if you do another exhaust system, make the flanges a little thicker. Use .062" compressed asbesos sheet and cut your own gaskets. If compressed asbestos sheet is no longer availiable over your way, use other high temp material of at least 600 F.
Also instead of flat flanges you can use Marmon clamps...rock on over to Demon Tweeks and see what they have....a lot cleaner but more $$$ (lbs.)
good luck
