LIghting Loads
LIghting Loads
LIghting Loads
When calculating the heat load from room lighting, what is the conversion from foot candles to Watts/Sq. Ft?
RE: LIghting Loads
I don't believe there is an exact conversion because foot candles measure the intensity of the light and some fixtures/bulbs are more efficient than others.
RE: LIghting Loads
If foot candles is a measure of intensity, how can it be used to calculate lighting heat load.  Wouldn't Watts/Ft^2 be the more sensible choice?
RE: LIghting Loads
new2 has hit it on the head.
There is no conversion because foot candles and watts are are fundamentally different quantities.
Foot candles are a measure of lighting intensity.  Watts are a measure of power.
The amount of power required to produce a foot candle of illumination is a function of the type of light source being used.  There is no "global" conversion factor.
