Resizing Revision block...
Hello All,
   I  am having issues with resizing of default settings of the title block and the revision block in the drafting workbench.  Is there any way to alter these settings without recreation of these features.
Thanks in advance Tim
RE: Resizing Revision block...
Your question is somewhat vauge.
Are you using script to generate the rev block?
If so you need to edit the values of the array inside the script.
