FTP code in VB
FTP code in VB
FTP code in VB
I am FTP-ing a file from the PC world to the UNIX world using an FTP command.  Right now I am using a Shell command to accomplish this FTP:
Call Shell(stSYSDIR & "ftp.exe -s:" & "c:\temp\ftpinput.txt", vbNormalFocus)
where
"stSYSDIR" is c:\winnt\system32\  and
"ftpinput.txt" contains my login and 'put' information.
This works fine for one file at a time.  When I have this call within a loop and sending more than one file, I error out and I think it's because the FTP is too slow to keep up with the VB code.
My Question(s):
Is there a better way to do FTP from VB?
Is there a 'wait' command that I can put after the FTP to allow it to catch-up to the VB?
I know I can group the files together and use mput...but that causes more problems than I think it will solve.
Thanks for any help.
RE: FTP code in VB
Perhaps you could try the following. First, in the VBA project, include a reference to the Windows Script Host Object Model.  Then in your code, at the point where you want to start the FTP process, do something like the following:
Private Sub cmdDoftp_Click()
   Dim lStr_CmdLine
   lStr_CmdLine = stSYSDIR & "ftp.exe -s:" & "<file one>"
   ShellAndWait lStr_CmdLine
   lStr_CmdLine = stSYSDIR & "ftp.exe -s:" & "<file two>"
End Sub
You may be able to put this is some type of loop or other mechanism that fits into your application.
Then add the following function:
Public Function ShellAndWait(rStr_CommandLine As String) As Long
   Dim lShl_WSH As IWshShell
   Dim lLng_RetVal As Long
   Dim lBol_WaitTerm As Boolean
   Set lShl_WSH = New IWshShell_Class
   lBol_WaitTerm = True
   lLng_RetVal = lShl_WSH.Run(rStr_CommandLine, vbMinimizedFocus, lBol_WaitTerm)
   Set lShl_WSH = Nothing
   ShellAndWait = lLng_RetVal
End Function
I use the minimized windows, but you can change that, or even pass it as second parameter as you see fit.
RE: FTP code in VB
CajunCenturion,
Thank you so much for your help.  I found for my application, the best solution was the ShellandWait function.  It works like a charm.  Thanks a ton to all you experts that help a dummy like me.  This forum has been a tremendous help to me.
mjs
RE: FTP code in VB
here's some VB source to do your own FTP. It's not mine, and I left the Authors name attached (Randy Birch!), but I have used it myself.
   Prerequisites
  Established network connection or personal web server/IIS.
  The Win32 API provides a distinct set of functions for connecting to, enumerating and downloading from the Internet. Some are specific to the connection protocol,
  ie FTP or Gopher, while others share a commonality making them useful across the range of connections options.
  This page presents one method of avoiding the VB Inet control in an application where the desire is to retrieve/list the files at a target FTP site. Subsequent pages
  will demonstrate downloading and other advanced techniques. This demo is not designed to perform as a perfect FTP client, but rather, through copious
  commenting, attempt to indicate the procedure for establishing the internet connection, obtaining the connection handles, and iterating through the FTP site's
  contents.
  An added bonus is demonstration of using the MSDN-provided TranslateErrorCode function. Since the GetLastError API most often can not be used for internet
  errors, this function translates the errors into a string. I added the API method InternetGetLastResponseInfo, which returns the meaning of extended error messages
  returned from Err.LastDllError.
   BAS Module Code
  Add the following code to a BAS module:
  Option Explicit
  ' Copyright ©1996-2001 VBnet, Randy Birch, All Rights Reserved.
  ' Some pages may also contain other copyrights by the author.
  ' You are free to use this code within your own applications,
  ' but you are expressly forbidden from selling or otherwise
  ' distributing this source code without prior written consent.
  ' This includes both posting free demo projects made from this
  ' code as well as reproducing the code in text or html format.
  Public Const MAX_PATH  As Long = 260
  Public Const FILE_ATTRIBUTE_ARCHIVE = &H20
  Public Const INTERNET_OPEN_TYPE_PRECONFIG = 0                      ' use registry configuration
  Public Const INTERNET_OPEN_TYPE_DIRECT = 1                         ' direct to net
  Public Const INTERNET_OPEN_TYPE_PROXY = 3                          ' via named proxy
  Public Const INTERNET_OPEN_TYPE_PRECONFIG_WITH_NO_AUTOPROXY = 4    ' prevent using java/script/INS
  Public Const INTERNET_FLAG_PASSIVE = &H8000000             ' used for FTP connections
  Public Const INTERNET_FLAG_RELOAD = &H80000000
  ' additional cache flags
  Public Const INTERNET_FLAG_NO_CACHE_WRITE = &H4000000      ' don't write this item to the cache
  Public Const INTERNET_FLAG_DONT_CACHE = INTERNET_FLAG_NO_CACHE_WRITE
  Public Const INTERNET_FLAG_MAKE_PERSISTENT = &H2000000     ' make this item persistent in cache
  Public Const INTERNET_FLAG_FROM_CACHE = &H1000000          ' use offline semantics
  Public Const INTERNET_FLAG_OFFLINE = INTERNET_FLAG_FROM_CACHE
  ' additional flags
  Public Const INTERNET_FLAG_SECURE = &H800000               ' use PCT/SSL if applicable (HTTP)
  Public Const INTERNET_FLAG_KEEP_CONNECTION = &H400000      ' use keep-alive semantics
  Public Const INTERNET_FLAG_NO_AUTO_REDIRECT = &H200000     ' don't handle redirections automatically
  Public Const INTERNET_FLAG_READ_PREFETCH = &H100000        ' do background read prefetch
  Public Const INTERNET_FLAG_NO_COOKIES = &H80000            ' no automatic cookie handling
  Public Const INTERNET_FLAG_NO_AUTH = &H40000               ' no automatic authentication handling
  Public Const INTERNET_FLAG_CACHE_IF_NET_FAIL = &H10000     ' return cache file if net request fails
  Public Const INTERNET_DEFAULT_FTP_PORT = 21                ' default for FTP servers
  Public Const INTERNET_DEFAULT_GOPHER_PORT = 70             '    "     "  gopher "
  Public Const INTERNET_DEFAULT_HTTP_PORT = 80               '    "     "  HTTP   "
  Public Const INTERNET_DEFAULT_HTTPS_PORT = 443             '    "     "  HTTPS  "
  Public Const INTERNET_DEFAULT_SOCKS_PORT = 1080            ' default for SOCKS firewall servers.
  Public Const INTERNET_FLAG_EXISTING_CONNECT = &H20000000   ' FTP: use existing InternetConnect handle for server if possible
  Public Const INTERNET_SERVICE_FTP = 1
  Public Const INTERNET_SERVICE_GOPHER = 2
  Public Const INTERNET_SERVICE_HTTP = 3
  'transfer flags
  Public Const FTP_TRANSFER_TYPE_UNKNOWN = &H0
  Public Const FTP_TRANSFER_TYPE_ASCII = &H1
  Public Const FTP_TRANSFER_TYPE_BINARY = &H2
  Public Const INTERNET_FLAG_TRANSFER_ASCII = FTP_TRANSFER_TYPE_ASCII
  Public Const INTERNET_FLAG_TRANSFER_BINARY = FTP_TRANSFER_TYPE_BINARY
  Public Const FTP_TRANSFER_TYPE_MASK = (FTP_TRANSFER_TYPE_ASCII Or _
                                         FTP_TRANSFER_TYPE_BINARY)
  'internet error flags
  Public Const INTERNET_ERROR_BASE = 12000
  Public Const ERROR_INTERNET_OUT_OF_HANDLES = (INTERNET_ERROR_BASE + 1)
  Public Const ERROR_INTERNET_TIMEOUT = (INTERNET_ERROR_BASE + 2)
  Public Const ERROR_INTERNET_EXTENDED_ERROR = (INTERNET_ERROR_BASE + 3)
  Public Const ERROR_INTERNET_INTERNAL_ERROR = (INTERNET_ERROR_BASE + 4)
  Public Const ERROR_INTERNET_INVALID_URL = (INTERNET_ERROR_BASE + 5)
  Public Const ERROR_INTERNET_UNRECOGNIZED_SCHEME = (INTERNET_ERROR_BASE + 6)
  Public Const ERROR_INTERNET_NAME_NOT_RESOLVED = (INTERNET_ERROR_BASE + 7)
  Public Const ERROR_INTERNET_PROTOCOL_NOT_FOUND = (INTERNET_ERROR_BASE + 8)
  Public Const ERROR_INTERNET_INVALID_OPTION = (INTERNET_ERROR_BASE + 9)
  Public Const ERROR_INTERNET_BAD_OPTION_LENGTH = (INTERNET_ERROR_BASE + 10)
  Public Const ERROR_INTERNET_OPTION_NOT_SETTABLE = (INTERNET_ERROR_BASE + 11)
  Public Const ERROR_INTERNET_SHUTDOWN = (INTERNET_ERROR_BASE + 12)
  Public Const ERROR_INTERNET_INCORRECT_USER_NAME = (INTERNET_ERROR_BASE + 13)
  Public Const ERROR_INTERNET_INCORRECT_PASSWORD = (INTERNET_ERROR_BASE + 14)
  Public Const ERROR_INTERNET_LOGIN_FAILURE = (INTERNET_ERROR_BASE + 15)
  Public Const ERROR_INTERNET_INVALID_OPERATION = (INTERNET_ERROR_BASE + 16)
  Public Const ERROR_INTERNET_OPERATION_CANCELLED = (INTERNET_ERROR_BASE + 17)
  Public Const ERROR_INTERNET_INCORRECT_HANDLE_TYPE = (INTERNET_ERROR_BASE + 18)
  Public Const ERROR_INTERNET_INCORRECT_HANDLE_STATE = (INTERNET_ERROR_BASE + 19)
  Public Const ERROR_INTERNET_NOT_PROXY_REQUEST = (INTERNET_ERROR_BASE + 20)
  Public Const ERROR_INTERNET_REGISTRY_VALUE_NOT_FOUND = (INTERNET_ERROR_BASE + 21)
  Public Const ERROR_INTERNET_BAD_REGISTRY_PARAMETER = (INTERNET_ERROR_BASE + 22)
  Public Const ERROR_INTERNET_NO_DIRECT_ACCESS = (INTERNET_ERROR_BASE + 23)
  Public Const ERROR_INTERNET_NO_CONTEXT = (INTERNET_ERROR_BASE + 24)
  Public Const ERROR_INTERNET_NO_CALLBACK = (INTERNET_ERROR_BASE + 25)
  Public Const ERROR_INTERNET_REQUEST_PENDING = (INTERNET_ERROR_BASE + 26)
  Public Const ERROR_INTERNET_INCORRECT_FORMAT = (INTERNET_ERROR_BASE + 27)
  Public Const ERROR_INTERNET_ITEM_NOT_FOUND = (INTERNET_ERROR_BASE + 28)
  Public Const ERROR_INTERNET_CANNOT_CONNECT = (INTERNET_ERROR_BASE + 29)
  Public Const ERROR_INTERNET_CONNECTION_ABORTED = (INTERNET_ERROR_BASE + 30)
  Public Const ERROR_INTERNET_CONNECTION_RESET = (INTERNET_ERROR_BASE + 31)
  Public Const ERROR_INTERNET_FORCE_RETRY = (INTERNET_ERROR_BASE + 32)
  Public Const ERROR_INTERNET_INVALID_PROXY_REQUEST = (INTERNET_ERROR_BASE + 33)
  Public Const ERROR_INTERNET_NEED_UI = (INTERNET_ERROR_BASE + 34)
  Public Const ERROR_INTERNET_HANDLE_EXISTS = (INTERNET_ERROR_BASE + 36)
  Public Const ERROR_INTERNET_SEC_CERT_DATE_INVALID = (INTERNET_ERROR_BASE + 37)
  Public Const ERROR_INTERNET_SEC_CERT_CN_INVALID = (INTERNET_ERROR_BASE + 38)
  Public Const ERROR_INTERNET_HTTP_TO_HTTPS_ON_REDIR = (INTERNET_ERROR_BASE + 39)
  Public Const ERROR_INTERNET_HTTPS_TO_HTTP_ON_REDIR = (INTERNET_ERROR_BASE + 40)
  Public Const ERROR_INTERNET_MIXED_SECURITY = (INTERNET_ERROR_BASE + 41)
  Public Const ERROR_INTERNET_CHG_POST_IS_NON_SECURE = (INTERNET_ERROR_BASE + 42)
  Public Const ERROR_INTERNET_POST_IS_NON_SECURE = (INTERNET_ERROR_BASE + 43)
  Public Const ERROR_INTERNET_CLIENT_AUTH_CERT_NEEDED = (INTERNET_ERROR_BASE + 44)
  Public Const ERROR_INTERNET_INVALID_CA = (INTERNET_ERROR_BASE + 45)
  Public Const ERROR_INTERNET_CLIENT_AUTH_NOT_SETUP = (INTERNET_ERROR_BASE + 46)
  Public Const ERROR_INTERNET_ASYNC_THREAD_FAILED = (INTERNET_ERROR_BASE + 47)
  Public Const ERROR_INTERNET_REDIRECT_SCHEME_CHANGE = (INTERNET_ERROR_BASE + 48)
  Public Const ERROR_INTERNET_DIALOG_PENDING = (INTERNET_ERROR_BASE + 49)
  Public Const ERROR_INTERNET_RETRY_DIALOG = (INTERNET_ERROR_BASE + 50)
  Public Const ERROR_INTERNET_HTTPS_HTTP_SUBMIT_REDIR = (INTERNET_ERROR_BASE + 52)
  Public Const ERROR_INTERNET_INSERT_CDROM = (INTERNET_ERROR_BASE + 53)
  Public Const ERROR_INTERNET_FORTEZZA_LOGIN_NEEDED = (INTERNET_ERROR_BASE + 54)
  Public Const ERROR_INTERNET_SEC_CERT_ERRORS = (INTERNET_ERROR_BASE + 55)
  Public Const ERROR_INTERNET_SEC_CERT_NO_REV = (INTERNET_ERROR_BASE + 56)
  Public Const ERROR_INTERNET_SEC_CERT_REV_FAILED = (INTERNET_ERROR_BASE + 57)
  ' FTP API errors
  Public Const ERROR_FTP_TRANSFER_IN_PROGRESS = (INTERNET_ERROR_BASE + 110)
  Public Const ERROR_FTP_DROPPED = (INTERNET_ERROR_BASE + 111)
  Public Const ERROR_FTP_NO_PASSIVE_MODE = (INTERNET_ERROR_BASE + 112)
  ' gopher API errors
  Public Const ERROR_GOPHER_PROTOCOL_ERROR = (INTERNET_ERROR_BASE + 130)
  Public Const ERROR_GOPHER_NOT_FILE = (INTERNET_ERROR_BASE + 131)
  Public Const ERROR_GOPHER_DATA_ERROR = (INTERNET_ERROR_BASE + 132)
  Public Const ERROR_GOPHER_END_OF_DATA = (INTERNET_ERROR_BASE + 133)
  Public Const ERROR_GOPHER_INVALID_LOCATOR = (INTERNET_ERROR_BASE + 134)
  Public Const ERROR_GOPHER_INCORRECT_LOCATOR_TYPE = (INTERNET_ERROR_BASE + 135)
  Public Const ERROR_GOPHER_NOT_GOPHER_PLUS = (INTERNET_ERROR_BASE + 136)
  Public Const ERROR_GOPHER_ATTRIBUTE_NOT_FOUND = (INTERNET_ERROR_BASE + 137)
  Public Const ERROR_GOPHER_UNKNOWN_LOCATOR = (INTERNET_ERROR_BASE + 138)
  ' HTTP API errors
  Public Const ERROR_HTTP_HEADER_NOT_FOUND = (INTERNET_ERROR_BASE + 150)
  Public Const ERROR_HTTP_DOWNLEVEL_SERVER = (INTERNET_ERROR_BASE + 151)
  Public Const ERROR_HTTP_INVALID_SERVER_RESPONSE = (INTERNET_ERROR_BASE + 152)
  Public Const ERROR_HTTP_INVALID_HEADER = (INTERNET_ERROR_BASE + 153)
  Public Const ERROR_HTTP_INVALID_QUERY_REQUEST = (INTERNET_ERROR_BASE + 154)
  Public Const ERROR_HTTP_HEADER_ALREADY_EXISTS = (INTERNET_ERROR_BASE + 155)
  Public Const ERROR_HTTP_REDIRECT_FAILED = (INTERNET_ERROR_BASE + 156)
  Public Const ERROR_HTTP_NOT_REDIRECTED = (INTERNET_ERROR_BASE + 160)
  Public Const ERROR_HTTP_COOKIE_NEEDS_CONFIRMATION = (INTERNET_ERROR_BASE + 161)
  Public Const ERROR_HTTP_COOKIE_DECLINED = (INTERNET_ERROR_BASE + 162)
  Public Const ERROR_HTTP_REDIRECT_NEEDS_CONFIRMATION = (INTERNET_ERROR_BASE + 168)
  ' additional Internet API error codes
  Public Const ERROR_INTERNET_SECURITY_CHANNEL_ERROR = (INTERNET_ERROR_BASE + 157)
  Public Const ERROR_INTERNET_UNABLE_TO_CACHE_FILE = (INTERNET_ERROR_BASE + 158)
  Public Const ERROR_INTERNET_TCPIP_NOT_INSTALLED = (INTERNET_ERROR_BASE + 159)
  Public Const ERROR_INTERNET_DISCONNECTED = (INTERNET_ERROR_BASE + 163)
  Public Const ERROR_INTERNET_SERVER_UNREACHABLE = (INTERNET_ERROR_BASE + 164)
  Public Const ERROR_INTERNET_PROXY_SERVER_UNREACHABLE = (INTERNET_ERROR_BASE + 165)
  Public Const ERROR_INTERNET_BAD_AUTO_PROXY_SCRIPT = (INTERNET_ERROR_BASE + 166)
  Public Const ERROR_INTERNET_UNABLE_TO_DOWNLOAD_SCRIPT = (INTERNET_ERROR_BASE + 167)
  Public Const ERROR_INTERNET_SEC_INVALID_CERT = (INTERNET_ERROR_BASE + 169)
  Public Const ERROR_INTERNET_SEC_CERT_REVOKED = (INTERNET_ERROR_BASE + 170)
  ' InternetAutodial specific errors
  Public Const ERROR_INTERNET_FAILED_DUETOSECURITYCHECK = (INTERNET_ERROR_BASE + 171)
  Public Const ERROR_INTERNET_NOT_INITIALIZED = (INTERNET_ERROR_BASE + 172)
  Public Const ERROR_INTERNET_NEED_MSN_SSPI_PKG = (INTERNET_ERROR_BASE + 173)
  Public Const ERROR_INTERNET_LOGIN_FAILURE_DISPLAY_ENTITY_BODY = (INTERNET_ERROR_BASE + 174)
  Public Const INTERNET_ERROR_LAST = (INTERNET_ERROR_BASE + 174)
  Public Type FILETIME
     dwLowDateTime As Long
     dwHighDateTime As Long
  End Type
  Public Type WIN32_FIND_DATA
     dwFileAttributes As Long
     ftCreationTime As FILETIME
     ftLastAccessTime As FILETIME
     ftLastWriteTime As FILETIME
     nFileSizeHigh As Long
     nFileSizeLow As Long
     dwReserved0 As Long
     dwReserved1 As Long
     cFileName As String * MAX_PATH
     cAlternate As String * 14
  End Type
  Public Declare Function InternetOpen Lib "Wininet.dll" _
     Alias "InternetOpenA" _
    (ByVal lpszAgent As String, _
     ByVal dwAccessType As Long, _
     ByVal lpszProxyName As String, _
     ByVal lpszProxyBypass As String, _
     ByVal dwFlags As Long) As Long
  Public Declare Function InternetCloseHandle Lib "Wininet.dll" _
     (ByVal hEnumHandle As Long) As Long
  Public Declare Function InternetConnect Lib "Wininet.dll" _
     Alias "InternetConnectA" _
    (ByVal hInternet As Long, _
     ByVal lpszServerName As String, _
     ByVal nServerPort As Long, _
     ByVal lpszUserName As String, _
     ByVal lpszPassword As String, _
     ByVal dwService As Long, _
     ByVal dwFlags As Long, _
     ByVal dwContext As Long) As Long
  Public Declare Function FtpFindFirstFile Lib "Wininet.dll" _
     Alias "FtpFindFirstFileA" _
    (ByVal hConnect As Long, _
     ByVal lpszSearchFile As String, _
     lpFindFileData As Any, _
  Public Declare Function InternetFindNextFile Lib "Wininet.dll" _
     Alias "InternetFindNextFileA" _
    (ByVal hFind As Long, _
     lpFindFileData As WIN32_FIND_DATA) As Long
  Public Declare Function InternetGetLastResponseInfo Lib "Wininet.dll" _
     Alias "InternetGetLastResponseInfoA" _
    (lpdwError As Long, _
     ByVal lpszBuffer As String, _
      lpdwBufferLength As Long) As Long
  Public Declare Function FtpGetCurrentDirectory Lib "Wininet.dll" _
     Alias "FtpGetCurrentDirectoryA" _
     ByVal lpszCurrentDirectory As String, _
      lpdwCurrentDirectory As Long) As Long
  Public Declare Function FtpSetCurrentDirectory Lib "Wininet.dll" _
     Alias "FtpSetCurrentDirectoryA" _
     ByVal lpszDirectory As String) As Long
  Public Function TranslateErrorCode(ByVal lErrorCode As Long) As String
  ' From       : MSDN
  ' Name       : TranslateErrorCode
  ' Purpose    : Provides message corresponding to DLL error codes
  ' Parameters : The DLL error code
  ' Return val : String containing message
  ' Algorithm : Selects the appropriate string
     Dim sBuffer As String
     Dim nBuffer As Long
     Select Case lErrorCode
        Case 12001: TranslateErrorCode = "No more handles could be generated at this time"
        Case 12002: TranslateErrorCode = "The request has timed out."
        Case 12003:
           'extended error. Retrieve the details using
           'the InternetGetLastResponseInfo API.
           sBuffer = Space$(256)
           nBuffer = Len(sBuffer)
           If InternetGetLastResponseInfo(lErrorCode, sBuffer, nBuffer) Then
              TranslateErrorCode = StripNull(sBuffer)
           Else
              TranslateErrorCode = "Extended error returned from server."
           End If
        Case 12004: TranslateErrorCode = "An internal error has occurred."
        Case 12005: TranslateErrorCode = "The URL is invalid."
        Case 12006: TranslateErrorCode = "The URL scheme could not be recognized, or is not supported."
        Case 12007: TranslateErrorCode = "The server name could not be resolved."
        Case 12008: TranslateErrorCode = "The requested protocol could not be located."
        Case 12009: TranslateErrorCode = "A request to InternetQueryOption or InternetSetOption specified an invalid option value."
        Case 12010: TranslateErrorCode = "The length of an option supplied to InternetQueryOption or InternetSetOption is incorrect for the type of option specified."
        Case 12011: TranslateErrorCode = "The request option can not be set, only queried. "
        Case 12012: TranslateErrorCode = "The Win32 Internet support is being shutdown or unloaded."
        Case 12013: TranslateErrorCode = "The request to connect and login to an FTP server could not be completed because the supplied user name is incorrect."
        Case 12014: TranslateErrorCode = "The request to connect and login to an FTP server could not be completed because the supplied password is incorrect. "
        Case 12015: TranslateErrorCode = "The request to connect to and login to an FTP server failed."
        Case 12016: TranslateErrorCode = "The requested operation is invalid. "
        Case 12017: TranslateErrorCode = "The operation was canceled, usually because the handle on which the request was operating was closed before the operation completed."
        Case 12018: TranslateErrorCode = "The type of handle supplied is incorrect for this operation."
        Case 12019: TranslateErrorCode = "The requested operation can not be carried out because the handle supplied is not in the correct state."
        Case 12020: TranslateErrorCode = "The request can not be made via a proxy."
        Case 12021: TranslateErrorCode = "A required registry value could not be located. "
        Case 12022: TranslateErrorCode = "A required registry value was located but is an incorrect type or has an invalid value."
        Case 12023: TranslateErrorCode = "Direct network access cannot be made at this time. "
        Case 12024: TranslateErrorCode = "An asynchronous request could not be made because a zero context value was supplied."
        Case 12025: TranslateErrorCode = "An asynchronous request could not be made because a callback function has not been set."
        Case 12026: TranslateErrorCode = "The required operation could not be completed because one or more requests are pending."
        Case 12027: TranslateErrorCode = "The format of the request is invalid."
        Case 12028: TranslateErrorCode = "The requested item could not be located."
        Case 12029: TranslateErrorCode = "The attempt to connect to the server failed."
        Case 12030: TranslateErrorCode = "The connection with the server has been terminated."
        Case 12031: TranslateErrorCode = "The connection with the server has been reset."
        Case 12036: TranslateErrorCode = "The request failed because the handle already exists."
        Case Else: TranslateErrorCode = "Error details not available."
     End Select
  End Function
  Function StripNull(item As String)
     'Return a string without the chr$(0) terminator.
      Dim pos As Integer
      pos = InStr(item, Chr$(0))
      If pos Then
            StripNull = Left$(item, pos - 1)
      Else: StripNull = item
      End If
  End Function
  '--end block--'
   Form Code
  Controls listed are from the form top down: To a new form add two labels for the handles (Label2/Label3), a combo (Combo1), one text box to reflect the FTP path (Text1), a list (List1, and a second text box for messages (Text2). There are
  four command buttons named Command1-Command4, one of which is not used here - see the FTP Download demo for its code. Add the following to the form:
  Option Explicit
  'persistent handle to the internet
  Private hInternet As Long
  'persistent handle internet connection
  Private hConnect As Long
  'default FTP login data
  Private Const sFtpUserName = "anonymous"
  Private Const sFtpPassword = "yourname@someplace.com"
  'constants are more efficient than literals
  'when used in several places
  Private Const sRootDots = ".."
  Private Const sSlash = "/"
  Private Sub Command1_Click()
     Dim sServerName As String
    'Show the wait cursor
     Screen.MousePointer = vbHourglass
    'Begin the FTP process by obtaining a
    'handle to an internet session. This
    'handle will be used in subsequent calls,
    'so its declared as a form-wide variable.
     hInternet = InternetOpen("VBnet FTP Transfer", _
                               INTERNET_OPEN_TYPE_DIRECT, _
                               vbNullString, _
                               vbNullString, _
                               INTERNET_FLAG_NO_CACHE_WRITE)
    'If a handle was obtained, the next step is
    'to obtain a connection handle that will be
    'used for all operations except the FTP
    'directory navigation. The MSDN states that
    'the handle used by FtpFindFirstFile and subsequent
    'file calls can not be reused for additional
    'navigation or other operations. This handle
    'then will be used for all functions except
    'the directory listings.
     If hInternet Then
        sServerName = Combo1.Text
RE: FTP code in VB
Hi mjs48
Check out the wininet api from microsoft. It contains internet connection and ftp commands. I have working vb programs running these ftp commands on both nt and xp
best regards
Richard
