www.dynamicfuel.com
www.dynamicfuel.com
I came across this website and find their product confusing. They claim that the electrolysis of 1.8L of water over 5000 miles can enhance the torque and power of a large desiel motor aka truck engine. This does not make sense to me since the electrolysis of 1.8L of water does not add to much hydrogen to start with and secondly they state the power for the electrolysis comes from the trucks alternator i.e engine. Anyone with a background in engineering should know that it will take more power in electrolysis of hydrogen/oxygen than you can ever get back due to burning that hydrogen in the motor? hence how the hell does it add torque/power?
Also I have heard of some research done in Munich using hydrogen as a fuel for a desiel engine and hydrogen was not used successfully as pre-detentation due to hot inlet tempertures always exsisted <--another issue they would need to solve.
Is this company a sham? how many people know of Genesis world energy lots of talk from reputable hydrogen authorities that they are a sham? kind Regards Mark
RE: www.dynamicfuel.com
Not the first time, nor the last. Snake oil is still for sale out there, and we engineers have a responsibility to let people know when we smell it.
Basis: 1.8 L JetfuelTM distilled water (100 moles H2O).
Energy required: 12 Amps x 12 Volts x 90 hours = 13 KWH = 46.7 MJ
Heat generated by H2O(g) formation: 100 moles x 240 kJ/mol = 24 MJ.
However, note that the improvement in efficiency is from the claimed complete combustion of the diesel fuel. We know that diesel engines are notorious emitters of unburned hydrocarbons, and in California, some engines are being retro-fitted with soot traps and catalytic converters. Might not a cleaner burning engine (also achieveable with 'cleaner' fuels) improve efficiency while alleviating the need for pollution control add-ons?
I would like to hear from someone who is familiar with this process and can explain any possible benifits. . .I'm all ears Kind Regards Mark
Kind Regards
After all, it would increase complexity and cost to separate them.
The H2 is too dilute to cause pre-detonation; there is only ½ Liter (at 25oC) + ¼ Liter of O2 available per mile (based upon 5000 miles per 1.8 L of distilled water).
Another Automotive thread dealt primarily with water injection, but more than 6 months old so search didn’t find. I suggested that direct injection of liquid DI water into a combustion chamber (right after either diesel fuel injection or gasoline engine spark) would improve mileage (steam engine effect), cut emissions (water would catalyze some of the reactions, plus lower peak T so less NOx) and possible longer valve life, etc. Some US fighter planes in WW II used direct water injection to boost horsepower.
Being a skeptic, I now wonder: Does the JetstarTM simply inject water vapor into the intake manifold?
As I posited above, it would improve combustion. Note that PJGD stated that combustion is no more than 95% complete in diesel engines in
Propane Injection + Water Injection Applications
Thread71-24712
Although I am skeptical also of this number, it does indicate potential greater efficiency.
The following thread may also be of interest:
Reducing NOX emissions in gasoline engines.
Thread71-44564
I should also like to hear from anyone with experience on this subject.
Ken
liquid chemical supercharging
Thread71-75887.
Thanks Mark
