Need a good tutorial for Cosmos FEA for Solidworks
I currently am evaluating a copy of Cosmos and am trying to learn to use it so we can implement it at my work. It seems fairly straight forward, but I am having trouble with surface force loading. I cannot figure out how to load just a portion of an objects surface. For instance I want to load just the top half and not the entire top side. If anyone can suggest a book, manual, tutorial, or whatever it would be super appreciated. Thank you.
David Fowler
David Fowler
RE: Need a good tutorial for Cosmos FEA for Solidworks
Any FEM book can help....To solve your problem recognise that pressure loads are applied to an entire element face so to get loading across a portion of a model surface just put loads only on the elements where you want the pressure and do not load the other elements....If that doesn't match the current element definition then redefine the elements so that it does....
Ed.R.
David Fowler
