INHOUSE NDT START-UP
I am examine the possibility of bring NDT inhouse (specifically MT, PT and UT) Yet I don't have a ANST Level III inhouse.
Option 1 - OUTSIDE ADMINISTRATION
Has any one used and outside ANST Level III to administrate , train and certify inhouse (Level I & II) personnel? What are the pro's and cons?
Option 2 - CERTIFY SOMEONE INHOUSE WITHOUT EXAMINATION
What about certifying someone in house with the training and experience as a LEVEL III without examination. The personnel would do the training , testing and certifying Level I & II personnel. (to get things rolling) Then when the ASNT exams are given, Basic and Specific, at a close location have the inhouse Level III take these exams.
Has anyone done this? Pro's & cons?
Rich
Rich
RE: INHOUSE NDT START-UP
No certification of any kind can be recognized without a ASNT level three involvment. if you are planning to develop an "in house" program you need a level three involved.
Many shop that I've been in used an out side level three for training and approval of procedure only. Once you are certfy to level two, you are allowed to work independently with in the confines of the approved procedures. Now the pro's and cons. "In house" level three program allows you to develop new procedures, keep personel currently trained while having the ability to perform inspections current with production rates. The down side is the cost of support a department that may not be need full time. If inspection is only what you need, but an outside agency does not suite your needs. Just send your designee to an outside school. Get them trained and certified, and if any of your procedures are out of the realm of accepted standards (ie: AWS D1.1) than use an agency's level three on a case by case bases.
As for certifying someone in house without examination, not many clients accept that option today. The latest versions of recommended practices for qualification and certification no longer allow that option. You can learn more about qualification and certification here: http://www.asnt.org/certification/guide.htm.
If you are interested in learning more about our NDT Level III consulting services visit www.brighttechnical.com.
William E. Blum
Managing Director
Bright Technical Services Inc.
wblum@brightechnical.com
USA Toll Free 1-877-638-2441
Fax/Voice Mail 1-435-417-3992
Sweden 46-42-14 39 99
