Configuration factor in swing check valves
Please send me complete information about these matters as possible as you can:
1:What is a configuration factor of a swing check valve and how can I calculate it?(in other hand,how many factors this factor depends on?)
2:How can I calculate the pressure drop in swing check valve?
With all of my thanks.
Iman salehinia.
Iman salehinia.
RE: Configuration factor in swing check valves
I am not sure what you want with question 1
A solution to Number 2
Contact the valve manufactorer for the pressure drop, they will have charts of flow verse delta P. If your fliud is not water you will have to adjust the values. Each design and size of check valve will have it own curve, none of which will be linear.
Hydrae
www.dft-valves.com
