Volume of water in a chilled water system
Is there any way you can determine the volume of water in a closed chilled water system by the tonnage, discounting the volume by pipe size?
RE: Volume of water in a chilled water system
However, depending upon the type of duty, a minimum chilled water volume would probably be from 3 to 7 litres per kW cooling (which is about 10 to 20 litres per TonR).
If you want to determine the volume of an actual system, you need to dissolve a known quantity of something in it and then, after sufficient time has elapsed to ensure mixing, measure the concentration.
Brian
