Heat exchangers
Heat exchangers
Hi. We have a pump with up to 100 metres head of suction and up to 200 metrs head of discharge. Delivery pipe is approx 200mm dia. We are trying to fit a heat exchanger to the control cubicle using the water in the pump lines but the exchanger is only rated for 10 bar. Does anyone know of a way this can be acheived without sending the water to waste. Regards Alan
RE: Heat exchangers
RE: Heat exchangers
RE: Heat exchangers
RE: Heat exchangers
Secondly, if it is possible to install the HE somewhere in the middle of the suction pipeline.
My third option would be as suggested by 25362.
Believe it or not : Though human body is made up of intricate and subtle mechanism, it is very poor in energy conversion. The maximum efficiency is 20% during cycling. During under water swimming it is just 4%.
RE: Heat exchangers
