Eccentricity
Eccentricity
Eccentricity
What is GT STRUDL recommendation for modeling a joint from
Tubesteel center to it outer surface.Would be just another
tubesteel or a ridid element which you cam model by specifiying eccentricity.From piping it is usually recommended to model the node from center of pipe to its
outer surface as rigid.Is it the same for GTSTRUDL.
Your recommendation is highly appreciated.
Ellie
