Press fit
Press fit
Press fit
I am trying to find the pressure distribution at the contact surface of a press fit assembly.
How can I model the press fit?
J
RE: Press fit
Juliana,
It is simple, but you can not perform this analysis yet in integrated mode. You must use the stand-alone version of Pro/MECHANICA.
If you are a maintenance paying customer, you can access the following document from the Technical Support Knowledge Base (www.ptc.com/appserver/cs/search/kdb.jsp):
Suggested Technique for Modeling Press-Fit Contact Analyses (www.ptc.com/cs/cs_23/howto/mst1293/mst1293.htm)
The basic technique is to model the initial interference so that the two bodies overlap and then use a contact surface for the two surfaces that will eventually be coincident. You will need a load to make an analysis valid, so if there are no other loads, use a dummy zero Global temperature load.
Best regards,
Matthew Ian Loew
"Luck is the residue of design."
Branch Rickey
RE: Press fit
I've put in an enhancement request to be able to do this in integrated mode.  When I checked today it's status was listed as "Pending".  I don't know what that means unfortunately.  Maybe in Wildfire 4
RE: Press fit
An easier method to be used in Integrated mode is this;
If you know the interference (displacement) of the press fit then you can work backwards by placing a pressure load on the female section until the interference displaecement is reached.  This value of pressure can be assumed to be the press fit pressure.
RE: Press fit
hi piston rod,
i am also stuck with interference fit contact analysis. And i liked the method that you have mentioned. but can you explain me with an example. please. i am desperate to know. thanks
Sari
RE: Press fit
Why not just create a spreedsheet that calculates hoop stress based on tolerances and temperatures.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
RE: Press fit
Heckler,
Performing closed form calculations is always a good idea. However, it will only work for geometry that has the stresses calculated from closed form equations. I have performed several press-fit calculations on irregular geometry. Using a FEM based solution was the only way to model the problem with accuracy.
Best regards,
Matthew Ian Loew
