Relation of Sonic Velocity and Density
I am looking to calculate the density of a material, using an ultrasonic thickness gauge. Through physical measurement of the part I can use the gaue to obtain the sonic velosity of the material. However I am in need of the formula that relates the sonic velosity of the ceramic to the desity. If any of you are falmiliar with this relationship, I would appreciate the help!
Will
RE: Relation of Sonic Velocity and Density
Sonic velocity is the speed of propagation of a pressure disturbance though a material. It is primarily a function of the translational and vibrational velocity of atoms a molecules since the disturbance prpogates from atom to atom. This is very dependent on temperature but not on density. If you campare a powdered material to its higher density solid form you will not find any difference in sonic velocity. The powder will absorb much more of the energy.
The longitudinal wave speed L in an elastic solid is equal to
    L = (E/rho)^0.5
where E = Young's modulus and rho = mass density. Solving for the density,
    rho = E/(L^2)
If you look up the modulus of elasticity, then you will be able to calculate the density of this material using the above equation. Good luck!
                                            Maui
You need to know Young's Modulus.
Thanks Maui,
That was exactly what I was looking for!!
