Diesel topping unit
Diesel topping unit
I am looking for information on oilfield production of diesel fuel. If you know of places on the internet where I could find some theory on diesel topping or manufacturers of skid-mounted topping units, please advise.
Thank you,
Andrey.
Thank you,
Andrey.
RE: Diesel topping unit
Best regards
The diesel product that the first pilot plant produced was tested successfully in the companies own over the road transport trucks as they delivered the companies products across the nation. The unit made #2 distillate, however, not the blended diesel that one can buy at the truck stop.
There is no reason why they could not scale the design up or down if you had an application that would be financially attractive for them to manufacture. The pilot plant used electric heat, and Dowtherm as the heat transfer fluid, but could use other combinations.
You might guess that I was the project/design engineer on that products development. Ask for Bill in the evaporator sales group, and refer to it as the DFS. Tell him someone from Monroe sent you.
