comparitor stability
Hey!
I am having difficulty stabilizing the output of a op amp comparitor in my circuit.  As the positive input changes and approaches the reference voltage at the negative input, the output doesnt stay stable at a high state.  The next device in my circuit which detects a high to low transition is picking up on every little change at the comparitor output.
Neo11
RE: comparitor stability
The usual solution is to add a positive feedback i.e. feed a small portion of the output back to the non-inverting input.
<nbucska@pcperipherals.com>
you must use a schmitt trigger to have a stable comparator
by using positive fidback.
if you dunno what is a schmitt trigger you can contact me
by this email address:
kasra_ravanbakhsh@hotmail.com
or see any electronic books!!!!
such as Integrated Electronics by Millman-Halkias
McGraw-Hill Book company
using an Schmitt trigger as comparator may help but
adding an ST after the comparator doesn't.
Two types of hystersis to condider as a fix....
1. DC (using a feedback resistor to the positive input)
2. AC + DC (using a feedback resistor in parallel with a
          feedback cap with a additional resistor in series
          with the cap, to the positive input)
Selecting one of the two to give the best results will depend upon your noise levels, shielding, S/N ratio and input signal type (fast/slow level changes). As a hint the feedback resistor values are usually very large to allow only 0.01 to 1% feedback and the caps are usually very small to allow faster switching (10 to 220pF typ) the resistor in series with this cap is usually 1/4 to 4x the value of the input resistance that feeds the comparitor ckt.
Hope this helps...
