How to obtain only silhouette!!!
If you are reading this probably you will answer me that I have to set "DISPSILH" variable to 1, but I can´t obtain the real silhouette.
Imagine a solid cylindrical bar and after bend it 90º (you will obtain a bar with a L form). If run 'hide' I obtain a mesh that represent the visible surface. To delete this mesh I set 'DISPSILH' to 1. When I run another time the 'hide' command the mesh has disappear, but there are two lines that seems to be joints. This joints divide the bended bar in three parts. One vertical part, one deformed part and one horizontal part.
Can you explain how to delete this joints??
Every answer will be welcomme and gratefull.
Thanks.
Thanks.
RE: How to obtain only silhouette!!!
Peter.
if everyone helps everybody the world will be a better place
