Gasket type and material in natural gas piping systems
In a natural gas medium pressure aboveground piping system, what type and material of gaskets have others used between a 125# cast iron valve flange and 150# steel pipe flange with the raised portion machined down?
Has anyone successfully used a spiral wound metal gasket?
RE: Gasket type and material in natural gas piping systems
I would not try to use a spiral wound gasket in your situation.
Do you think there is some need for the spiral wound, ie fire?
Thanks for your response.
Have you ever used the Flexitallic type CG when connecting the 150# steel pipe flange to the 125# cast iron valve flange?
If you have did you have any problem with stressing the cast iron?
