Exporting MathCad to specific Cells in Excel
I need to export data from MathCad to specific cell ranges within Excel, where normally in MathCad it automatically starts at A1, where I want it to start at A3
Can someone tell me if this is possible!!!!!!
RE: Exporting MathCad to specific Cells in Excel
Hi!
I suggest you export data from Mathcad first to one Excel sheet, and then link that to a second Excel sheet where the data is re-written in a convenient place.
In case you want data to be passed back to Mathcad from the second Excel sheet after a table lookup, I suggest you use string function str2vec() to pass data from Mathcad to the first Excel sheet, re-convert to string using CONCATENATE function in the first Excel sheet itself, and then use the re-created string to do a LOOKUP in the second Excel sheet.
The idea is that Excel files talk quite well among themselves, while the interfaces with Mathcad are more rudimentary.
Hope this helps!
