fire damage to gears etc
If a machine is in a fire, (catches on fire)is there an
easy way to check gears etc. ie: suppose an excavator
catches on fire and burns. Some of the aluminum parts
external will melt, (alternator etc) but the piston inside
the engine will not melt. The planetary gearbox to make the machine swing costs upward of $30k. It is common to
throw it out and not salvage any of it. Would this really
be no good? How can you check?
thanks.
thanks.
RE: fire damage to gears etc
