GeoFoam as a structural fill
Hi, folks!
We are trying to use GeoFoam as a structural fill for the railroad. The vertical and longitudinal forces are very high, special worries are about shear transfer between layers o geofoam blocks. The force is about 40 lb/sft. If anybody has an experience in it or knows where to look? Please, help!
Yakov
Yakov
RE: GeoFoam as a structural fill
Were you ever able to find any information on this material? I am looking into using it for fill in an abutment for an elevated roadway, but need to learn more about it. My primary concern is how it acts in a seismic event. What sort of lateral loads would we expect to see from the foam blocks on the abutment wall?
TSM
Yakov
esearch Institute.
Check out www.elastizel.com or www.maxflow.com
Both have geotechnical applications for cellular concrete.
rjakiel@kersur.net
Thanks for suggestion. We, actually, used lightweight concrete (Elastizell, 30pcf) on the other project. Foam concrete is more expensive than geofoam and the project I described is about 3000 feet long.
