EHV cable directly buried
HI, I am trying to specify the installation of a 132 kV XLPE cable to be buried directly in the ground.
Can anyone give me information about the method of laying, type of backfill, size of trench (depth, width) , laying arrangment, bonding, etc....
I will have also to lay in the same trench a fiber optic cable, a control cable and earth cable. Is there a minimum distance to be respected from the 132kV cable ?
I would appreciate any additional technical information or internet site address.
THank you
THank you
RE: EHV cable directly buried
No specific chemical hazard has been identified on site.
NOte : THe cable is intended to connect a cogenration step-up transformer to a 132 kV switchyard.
