Lisp that draws ceiling grid - like 2'x4'
Does anyone know where to find lisp that draws ceiling grid - like 2'x4' within a selected entity?
Thx
RE: Lisp that draws ceiling grid - like 2'x4'
Could you use a hatch pattern, such as GRATE or NET, scaled as you need?  If these do not work, you may have to create a hatch pattern that has the proportions of your tiles.
How about drawing the first horizontal and vertical lines, then using the array command.
I found a routine at
http://www.cadalyst.com/code/browseyear.cfm?fullyear=20...
called Ceiling Grid Enhanced. I have not tried it but it sounds like some thing that you might could use. You will have to register to get the code. It is located in March 2000.
Hope that this helps.
Charles S. Parnell
Southern Store Fixtures
