mathematical model for industrial scale downdraft gasifier
I am looking for a mathematical model which analyses a downdraft gasifier that I can use to model our industrial scale gasifier unit. I am specifically looking for a model which considers particle movement and gas flow down the gasifier (along the gasifier axis). Biomass (wood) would be the fuel source. The heat-transfer and mass conversion (during pyrolysis) should also be considered.
If you know of a suitable source from which I can obtain this information, I would be very grateful for your help.
RE: mathematical model for industrial scale downdraft gasifier
Are you still in need of this information ??
I can find the worksheets, & simulation program I used.
Reply to this thread if you still need it.
I've set "e-mail notification" for the thread, I don't want to go through all of it, IF you no longer need it..... :)
Greg, Also called "Mr. Fusion" by the locals
I am still interested in obatining the information.
regards
Revata
Greg :)
Greg,
Called "Mr. Fusion" by the Locals :)
In regards to the post in "Eng-Tips.com"
Thread124-76082
Enclosed below is the page that I got the modeling software from.
Please, if you use this model, follow the guidelines.
http://bgg.mek.dtu.dk/research/modelling/systems/
The version I downloaded, sometimes, when you open it, will give an error on the first time you use the "recalculate" button (don't know if this is a software bug, or my computer) if this does happen to you, I found that even if you close and re-open the program, it will always give that error UNLESS you do a reboot, then try again (personally, I think it's my computer, simply because it's a clunker :)
As far as my worksheets, I don't know if they would apply, as what I'm doing is a "District Heating" type system, approx. 30kg/h of bio-mass (quite a small system, compared to what you want, and therefore the surface area of the unit would throw your calculations off).
Let Me know.
Regards, and Happy Holidays
Greg
Greg,
