Underpinning of structure
Will there be any new technology where we can stabilize the foundation of existing structure aside from jet grouting procedures? especially in areas of limited space without affecting much the adjacent structures? please advise anyone thanks
RE: Underpinning of structure
Helical screw piles can be used to underpin. However, like anything else, you will have to determine if your situation allows this concept to be used. You may wish to solicit the views of a geotech engineer and screw pile contractor.
A bit more information on your particular problemmay be useful to obtain other ideas.
The equipments to be used is also a factor just wondering if the helical screw piles can best fit in the situation.
Just a thought.
Talk with the geotechnical engineer for the project, he/she should be able to give you a shorter list customized for the project.
