Grey Iron
Grey Iron
Just wondering if anyone can help. I need to do a university project on Grey Iron BS EN 1561:1997 just wondering if anyone can give me any tips on where to go about getting information. Kinda struggling a bit searching the web.
Thanx :)
Thanx :)
RE: Grey Iron
RE: Grey Iron
http://www.ironcasting.org/Gray%20Iron%20-%20A%20Unique...
Also check you libery for information form the "Grey and Ductile Iron Founders' Society"
They had a book called the Grey Iron Casters Handbook. This was na excellant book.
RE: Grey Iron
Do you intend – a review paper, experimental research toward a degree..?
Do you have foundry and analytical facilities? Research money?
The following description is from British Standards Online (http://bsonline.techindex.co.uk/):
BS EN 1561:1997 Founding. Grey cast irons
22 pages, £54.00 (non-member price).
“Descriptors: Foundry engineering, Production metallurgy, Castings, Grey cast-iron, Unalloyed cast-iron, Cast-iron, Thickness, Tensile strength, Hardness, Tensile testing, Test specimens, Dimensions, Proof stress, Elongation, Compressive strength, Yield strength, Strength of materials, Modulus of elasticity, Poisson ratio, Specific heat, Thermal expansion, Density, Thermal conductivity, Electrical resistivity, Coercivity, Permeability, Brinell hardness measurement, Symbols, Grades (quality).”
Seems like you have a wide selection of variables.
Casting Industry Trade Organization (looks like U.S. only) links, see http://www.afsinc.org/AFSIS.htm
Online articles (http://www.moderncasting.com/): click on Modern Castings Archives, then Website Articles Archives. Several papers on gray iron.
Unfortunately, the Gray and Ductile Iron Founders' Society seems to have gone out of business. The Ductile Iron Society and Iron Casting Research Institute (links in above list) may be continuations of sorts.
The most recent editions of the book mentioned by unclesyd:
IRON CASTINGS HANDBOOK Covering Data on Gray, Malleable, Ductile, White, Alloy and Compacted Graphite Irons -- Walton, Charles F. , ed. (1981). 831 pages
GRAY AND DUCTILE IRON CASTINGS HANDBOOK: Including Data on Gray, Ductile, White and High Alloy Irons-- Walton, Charles F. , ed. (1971). 679 pages.
I have the 1971 edition. An excellent book, but it doesn’t mention non-US standards.
For an Internet search (277 journal articles):
http://www.scirus.com/search_simple/?frm=simple&query_1...
Hope this helps. Also search with the ‘grey’ spelling, 336 journal articles!
Ken
P.S. Thanks to either TVP or TEV for first recommending the www.scirus.com search engine.
RE: Grey Iron
Actually it was CoryPad that first mentioned Scirus. Quite the search engine, eh? Elsevier certainly has some incredible resources.
RE: Grey Iron
RE: Grey Iron
Meehanite Metal (US) http://www.meehanitemetal.com/
INTERNATIONAL MEEHANITE METAL COMPANY LTD(UK) http://www.meehanite.co.uk/indexe.html
They make and license a full line of cast irons. Re Grey:
"The Metallurgy of MEEHANITE Flake (Grey/Lamellar) Iron
In the production of Meehanite flake graphite castings, the composition of the iron, whilst important, is only a part of the process for achieving a definite metal structure. The more important factor is mass, ie wall section thickness, and its effect on cooling rates. For normal cast iron, slow cooling (as in thick sections) produces a coarse open-grained, low strength structure, whereas fast cooling (as in thin sections) results in a hard, brittle, unmachinable structure. Thus in Meehanite practice, the structure of the metal and properties required are related to the section thickness of the casting."
"For more information on this subject why not email us and ask for a copy of the brochure: "MEEHANITE Flake Graphite Irons for General Engineering Applications""
RE: Grey Iron
http://www.scientific.net/default.cfm
RE: Grey Iron
