BJT Transistor Question
I'm studying for the PE exam and am trying to refresh myself with transistor circuits. Everything has been making sense up to this point. Then I ran across the problem given below.
Can someone please tell me if there is an error in the problem or solution. It seems to me that a 5.4 volts swing on the OUTPUT rather than the INPUT would cause saturation. Because of the large gain of common base configurations, a much smaller input voltage would cause saturation. Am I missing something?
RE: BJT Transistor Question
