rotary swith,leadwell manual
Can anyone tell me where to get a manual and electrical diagram for a Leadwell ltc-15 turning center.  Controller is fanuc ot.  The component with a problem is the rotary switch on the turret shaft.  Tool position 8 does not happen.  I suspect one pair of wires is disconnected.  I can not read the mfg on the switch.  It is type HS-04008FAP2. SN 04348  24VAC.
Robert Setree
www.advanced-grinding.com
