Developments/flat pattern views on catia drawings
I have an ice cream cone object drawn and want a development view a.k.a. flat pattern view on the drawing of the cone. It is not a solid...it's wall thickness is approx. 1/32". It seems like I have asked everyone from instructors to catia guru's and still have no answers. Any help will be appreciated.
RE: Developments/flat pattern views on catia drawings
V4 or V5?
Are the sides of your 'cone' straight? (ruled surface?)
The cone is straight edged. Front view would be a triangle, top view would look like a circle with the top point in the center. I was told to sketch it, revolve it, then using the sheet metal design workbench to unfold it, however it does not work. In solidworks it is a lofted bend command, then flatten...but not sure how the catia works it.
In V4, you can do this with DEVELOP
Not sure about V5 - maybe SHEETMETAL workbench?
I just found this in another CATIA forum:
Unfold icon is available in CATIA V5R12. It belongs to Developed Shapes product. It can make a flat pattern out from developable surface (like V4 DEVELOP function).
Good luck.
Thanks Jackk, I appreciate your input. An instructor has told me about the R12 flat pattern option. There's a way to do it on R10 and R11...just nobody knows of it.
Again, thank you for your time Jackk.
So, please share with us how to do it in R10 and R11.
