SW2004 Drawing problem
Every time in sw2004 i go and change the scale under edit sheet my title blocks with our company name will go back to the general out of the box title block, what is strange our company name ect.. is gone. Is this a bug, because i did not have this problem in SW2003.
RE: SW2004 Drawing problem
When you are in the sheet properties dialog, make sure that you are not changing the sheet format.
This is assuming that when you are changing scale you don't mean you are changing sheet size B to C etc.  You are actually changing from 1:5 to 1:10.
This scale change should have no effect on the sheet format.
