Can I convert Solid Edge assys and parts to I-Deas ?
I got an assembly from Solid Edge V12. Is it possible to convert parts (or the complete assembly) into I-deas 10m1?
And if this is possible, is it also possible to convert the history of the parts and constraints?
RE: Can I convert Solid Edge assys and parts to I-Deas ?
I-DEAS 10m1 has a Solid Edge Part option under Unigraphics Open in the File menu.
You won't, however, be able to bring in the history and constraints of the part.
To bring in an assembly, do you have a STEP export from Solid Edge? I-DEAS can read in STEP assemblies.
