Where for standard fitting dimensions
I have dimensions for almost all the fittings I'm using except for a threaded union Female X Female, 1 1/2"NPT. I need to squeeze a threaded union through another pipe for assembly...and the pipe does not strech very much :<)  Where can I find dimensions for a standard threaded union (I need the nut size and the thread size for the union part too.... I suppose I could just run to the hardware store, but that seems a little silly.
Thanks for the help.
RE: Where for standard fitting dimensions
This all I can come up with
http://www.wardmfg.com/PartSearch.asp?PT=F
This will give you part of what you need with a little effort.  I have a QC manual from Stockham somewhere I am trying to find it.
Very cool.
Thank you
