Jetcam for flat development
Is there anyone who can comment on this software? We are sheet metal fabricators. I like to get it for our engineering group for flat development from 2D or 3D drawings.
Based on its brochure, it can easily take 2D or 3D files and convert them into flats.
RE: Jetcam for flat development
I was just looking into what is out there for blank development.  Many useful tools at http://www.forming.com
If the ladies don't find you handsome, they should at least find you handy.
hi,
Pro-Engineer with Sheetmetal module is one option which is very good.  This gives true seamless integration starting from 3-D sheet metal design to flat componnet to NC file for your CNC machine.  This solution is not useful for converting old 2-D files to flat.  I did lot of research on this problem but could not find easy answer.  Finally, went for Pro-E.
Prakash Sonar
