Drawing a spring
Drawing a spring
Hi everyone
Does anyone know how to draw a spring using SW
What I need is about an inch long and about 1\2 OD is there
a library .
Thank as I am new to SW any help would be good.
Yvonne
a library .
Yvonne
RE: Drawing a spring
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
select the circle,
then go to insert- curve -helix
give the parameters (like pitch, revolution...)
create one plane perpendicular to that helix at the starting point(use ref geomentry- per curve option- select starting point of helix and helix curve)
now create circle for spring cross section(its center should be coincitant with starting point of helix).
then select insert - boss- sweep - select circular cross section and helix path.
now u can get spring.
regards,
murugan
INDIA
Torsion spring design from closed position. Multiple configurations for free, open, and closed positions.
Also consider are you modelling free length or compressed length (as installed)? A very interesting topic!
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
