Definition of Terms
Definition of Terms
Does anyone have a good definition of accuracy vs. resolution vs. repeatability?
Steve
Steve
RE: Definition of Terms
Resolution (discrimination)= the smallest graduation of an instrument that you can record
Repetability = the range of readings obtained by repeating measurements by the same operator on the same instrument and the same part.
In addition I consider accuracy to be the range of readings obtained by repeating measurements by the same operator on the same instrument and the same part (which may be far from close to the true value). I have the same interpretation on resolution as stel8.
Jack.
