Need Deaerator - oxygen removal calc
I am looking for the necessary calculations needed to find the pick-up velocity for a deaerator.  Currently orange juice is entering the deaerator with 8ppm of oxygen and I need to verify that the orange juice will leave with 3ppm of oxygen.  Any help would great, thanks alot.
RE: Need Deaerator - oxygen removal calc
Firstly, You should know that your deaerator is not functioning effectively... It should not produce oxygen levels above 7ppb.. I would fix the deaerator befor looking at anything else......Countryham
