DI water cooling tower
I'm wondering if anyone knows what kind of chemicals are needed for a cooling tower (Assuming that the cooling tower is upgraded to handle corrsion problem) that uses DI water instead of raw water. What would the blowdown rate be? Thanks a lot!
RE: DI water cooling tower
A lot depends on you system layout and what the demands on it are and possible contaminates along with the materials of construction.
Believe it or not : A Neutrino is so mass less(and electrically neutral) that, a conservative estimate states, it can pass through a 50 light year thick lead block.
http://www.awt.org/
The article on "white rust" is very informative.
The also have a lot of good links.
Fix circulating cooling water quality. From the make-up watr quality, you will be able to find out the blowdown rate and make-up rate. Contact the cooling water chemical dosing suppliers for the chemical dosing and they will also advise you the blow down rates.
