Registry User Interface
I've read the FAQ 559-655 and followed this procedure successfully in the past.  Now however it does something to prevent SolidWorks from even starting!
The goal is to populate new computers with our current SolidWorks User Interface, which basically sets all the customized toolbars on/off and their locations.  Any similar experiences?
RE: Registry User Interface
I am not positive but I believe all you have to do is copy the user.cus file from one machine to another to get similar layouts on multiple installs.
The problem with that FAQ (no offense to the writer of that of that FAQ) - SW doesn't support that reg hack for saving your toolbars - it is a use at your own risk.
The *.cus file your talking about aamoroso is the file for your keyboard shortcuts and can be copied to the original user of that file - EX: sbaugh.cus - hence my log on name.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
SBaugh
In your opinion, if we save registry entries for SW (hkey_local_machine\software\solidworks\solidworks2004) and pass them to another computer, does the tool bars (and other options) get properly updated?
Update.
After exhaustive testing on two identical Dell machines I've found the following:
1. *.cus file had no apparent effect on toolbars, macros or hotkeys.
2.  Exporting via the regedit command:
HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2003\User Interface was the best way to transfer toolbars.
3. Destination machine had to have the above mentioned HKEY deleted from it's registry prior to importing the copy from the source machine. If this was not done SolidWorks would not start at all until it was deleted and replaced with a fresh HKEY.
4. Still looking for a solution on macros and hotkeys.  HKEY_CURRENT_USER\Software\SolidWorks\SolidWorks 2003\User Defined Macros... doesn't accomplish this by itself.
The *.cus file found in the folder C:\Program Files\Solidworks\user\
Is the only file that contains your Keyboard shortcuts. If you haven't made any then you won't have that file or that folder. The best way to test it is to install SW04 as a new installation and in a new directory. Then copy the User file folder into your SW04 directory.
There is no Reg hack for your keyboard shortcuts that I'm aware of.
Scott Baugh, CSWP
FAQ731-376
